RCU Forums - View Single Post - Painting a cowling, doing it right this time - I hope
Old 07-27-2002 | 06:56 AM
Giant Scale
Default Painting a cowling, doing it right this time - I hope
ilikeplanes,
I guess your mind is made up. I have not experienced the problems you have had with this paint. I have used this paint both indoors and inside my garage and the paint drys without any problem. I try to paint when the humidity is relatively low and the temps are in the 70-80 degree range. The methods I use to paint with are pretty standard and yield excellent results. Where are you located? Usually paints have longer drying times is cool or rainy climates, I have not tried to paint on rainy days. Rustoleum makes a brand called painters touch which lacks the rust inhibiting additive, these paints dry very quickly. Usually you can recoat in 20 minutes whereas the stops rust paints require a couple of hours. Well good luck with you painting.
