How to move from a trainer?
Hi RC. I've also just started out this year and just went from a trainer (Superstar 40) to an SE that I built during the Spring. I've had it up about a dozen times now and find it to be a lot more fun to fly than my trainer! A few tips...don't use the control rates that they recommend when you first start flying it. I set everything pretty low (maybe 30 - 40%) on low rate and left it at about 60 - 70% on high rate. At the lower setting and at about half or third throttle, it's very easy to fly. I also went with a 46FX for the engine so it is not too much to handle. I also feel that it is just as easy (easier in some ways) to take off and land than the tricycle landing geared trainer. I also think that the 4 Star would also be a good second plane. Whatever you choose, make sure to ask for help from some of the more experienced flyers when you begin to trim it out. This is definitely an "addictive" hobby! Good Luck...Len
