RE: how do i know if my car is 190mm or 200mm?
You can run some 200mm bodies on some 190mm cars if you use offset wheels and spacers. And you can use some 190mm bodies on some 200mm cars if you trim the wheel wells a bit (the wells sit right over most tires).
