RCU Forums - View Single Post - Radio interference using servo y connector
Old 08-17-2004 | 07:32 AM
0ldog
Default RE: Radio interference using servo y connector
Try making a loop in one of the aileron servo leads if that doesn't work try adding an extension to just one of the servo leads. With your Y connector and equal length servo leads you in essence have a center feed di-pole antenna prone to picking up stray RF. Worth a try, good luck.
