Ok, thanks for the input. Let me see if I can clarfy.
[ul][*] I plan to build this plane from scratch with the help of other pilots. [*]I'm trying to render the plane to see if it is airworthy before wasting any money. [*] This will certainly have an EDF[*]
If possible, create a fuselage shape that is low drag at low angle of attack, but can add lift when pitched "up" into the turns.
Did you mean a wide fuselage?
[/ul]
