First Plane
Hi dbow,your plane, engine is a good trainer,as far as the covering goes hot sun can be a problem,the covering will get loose with the heat ,then shrink when it cools down,I like the 6 ch futaba, as far as servos,use what comes with the radio,10X6, 11X6,works fine,apc or wood to start with can get expensive,they break easy on not so perfect landings so I've heard?? BEST ADVICE,find a club with an instructor that you like and have fun.
