RCU Forums - View Single Post - First Plane
Thread: First Plane
Old 08-06-2002 | 12:35 PM
  #40
dbow's Avatar
dbow
Default Update
The plane is coming along, I have glued the wings and cut the servo hole for the ailerons. Im having to do a little more cutting and fitting than I thought I would, but having fun doing it.
I also installed the tail fins and I think I got them fairly close to perfect on the alignment.
I did have one problem though, When installing the ailerons on the wings I screwed up big time. I put the little hinges in the slots then pushed the aileron into place. I pulled it out slightly so I could add some glue, well I think you know what happen. It took about 4 or 5 seconds for me to apply the glue to all hinges, by the time I tried to push it in it was seized. Well I did get them out and was able to do so without causing any real damage.
I put them all the way back in and then applied the glue with a toothpick. There is a slight gap between the aileron and the wing but very slight on that side.
Right side turned out good now that I know how to add the glue.
Im not impressed with the directions for this plane, there are a lot of steps that it just does not mention. Being a first plane and all I thought they would be a lot more descriptive. There are a ton of steps where mistakes can be easily made and no turning back basically. Im not saying its hard to build, its quite easy actually and Im already thinking of my second plane. I just think the directions could be better.
Well I have not had much time to build but getting there, the engine and radio come this week along with props and balencers and all that good stuff.
I should have this thing ready in another week or so depending on how much time I get this weekend.
Will post some pictures of my progress when I get home tonight.
Again, thanks for all the help and suggestions.
Dbow
