RCU Forums - View Single Post - First Plane
Thread: First Plane
Old 08-06-2002 | 09:17 PM
  #46
TerrellFlyer
Default First Plane
Even if sealing the gap doesn't stop all flutter,it helps ,also sealing the gaps on every control helps the efficiency of the airflow,agree it doesn't show up as much on a trainer when you first start learning,but every little bit helps,also if your're going to do something ,do it right the first,learning bad habits can be hard to break later
