RE: 9C Mixing Question- Double Vision Biplane
Hi Mike,
If you have just one Pmix left, you can do just one mix with Rudder to Aileron with Link on, this will make anything that aileron is "linked" to (in the original first mixes) move in conjunction with the mix that you just created. If you don't have a spare Pmix, then you might want to try redoing this with the other mix I suggested.
Thanks, Krysta
