RCU Forums - View Single Post - G-Trick 90 CG? Throws?
Old 08-18-2004 | 03:41 PM
rwlewis
Default RE: G-Trick 90 CG? Throws?
CG - 165mm from LE. Manual does not specify, but I assume it means at the fuse side.
Elevator throw - 14mm low rate/40mm high rate each side of center. Measured at the inboard tip of the elevator counterbalance.
Aileron throw - 16mm low rate/23mm high rate each side of center. Measured at the inboard tip of the aileron TE.
Rudder - 40mm low rate/60mm high rate each side of center. Measured at the forward tip of the rudder counter-balance.
Richard
