RCU Forums - View Single Post - Homelite 33cc conversion
Old 08-18-2004 | 09:57 PM
av8tor1977's Avatar
av8tor1977
Default RE: Homelite 33cc conversion
Yes, those are the adjustment screws. If you can, grab them with a pair of needle nose pliers, or a pair of hemostats, and count the turns to gently close them. Write this down, and then unscrew them all the way out. Then use your dremel tool with a cutoff wheel, and grind some screwdriver slots in them.
Hope this helps,
Good luck,
AV8TOR
