RCU Forums - View Single Post - Will this work..or is it...
Old 08-19-2004 | 04:05 AM
Prope
Default Will this work..or is it...
Will this work..or is it too big?
I've decided to build an airboat in my spare time. I plan on building it out of 9mm plywood all round, and powering it with an OS 25 LA engine. If I stuck to these plans, would it A)work well, and B)be powered well enough by the 25 LA to get some decent speeds out of it when using a 9x6 propeller?
At the moment I'm wondering if 5" is too much for the height, and maybe I'd be better off building it a bit lower?
Also, is 9mm a bit drastic - would 3mm or 6mm plywood be best?
Marc.
