RCU Forums - View Single Post - Do I have everything I need?
Old 08-19-2004 | 06:11 PM
DrFun's Avatar
DrFun
Default RE: Do I have everything I need?
all look good and agree with 7CAF thats a good one and I started with 6yg which was a big mistake because with the second plane I needed a camputer radio.
I believe the 46AX uses A8 not the A3.
For 5 min epoxy, you realy don't need it in mu opinion whe you need use 30 min expoxy.
Get couple of 11x6 or 11x5 props at least 6 of them they should have package you will need them when you start landings.
Get the fuel from you LHS. a quart will not last long and buying from fuel tower is not good due to extra charge.
If you are not a member and plan on spending more on Tower, get the tower membership for $15 with order you will be fit with you next order.
A11 hobby nife is missing if you don;t have one, and get some extra blades.
You might take a look at fuel line fittings for the fuel bottle great planes ones does the good job.
If you can afford $30-40 more get the 12V 7.5A battery and electric starter, makes life easier and safer for the fingers.
Averything else looks good. Don't forget the $20 off coupon on the home page
Have fun, as suggested you can still leave your credit card in your pocket and walk away, if not welcome to addiction.
