RE: Prop balancing
You need to sharpen and balance a prop. Balancing does reduce vibration which can cause stress cracks in the hull and screws to come loose plus premature wear on driveline parts. Sharpening will cut through the water easier, increasing speed and reducing propwalk on boats that have that problem.
