RCU Forums - View Single Post - Prop balancing
Old 08-19-2004 | 10:28 PM
MikDee
Default RE: Prop balancing
If you are running a shaft tube for a solid driveshaft, 1/8", 4mm, or 3/16" you can BEND the shaft with a prop out of balance, or Wear Out the shaft tube, causing the prop to spin in an ever increasing circle, keeping the boat from planing, and letting water in!,,, ask me how I know?,,, Been there, Done that!
