RCU Forums - View Single Post - Pull/Pull vs. Pushrod on SR Eindecker
Old 08-20-2004 | 07:19 AM
Larry @ SR
Default RE: Pull/Pull vs. Pushrod on SR Eindecker
Boy, if there was ever anything that wasn't possible, it's wing warping with our Eindecker E1. You wouldn't believe how stiff that wing is.
During construction of the wing there are instructions to simply block up one of the building jigs at the tip by 1/4" which will end up giving you about 3/8" of washout in each wingtip. Once the wing is built, forget about changing it. My standard method of removing warps or adjusting washout with the covering material just isn't possible. The jigs and fixtures that are included in the kit will give you a straight wing and it's going to stay that way forever.
Larry
