RE: Second Thoughts...
I am not flying a U Can Do but do have a plane of the same type design. It was my second plane as well. The thick airfoil 3Ders like the U Can Do are very easy to land, they float for a while. If you have someone help you to trim it out and to set your rates pretty low you shouldnt have many problems with it. Buddy box it till you are comfortable with it. While probably not the ideal second plane, as long as the plane is good and trimmed out, rates are set pretty low and you fly at modest throttle you should be able to fly it if you have mastered your trainer.
