kyosho AT-6 Texan
One other detail I forgot... I tried to keep the exhaust hole in the cowl small and it made the 4-stroke overheat after a few minutes so I had to open a larger rectangle in the bottom to pass some air as the wood ring for the cowl is a good way to mount, but restricts air passing around the fuse...
