props tighting problems ???
I have a OS 120 four stroke w a APC prop +Great plane spinner and my problem is the prop and the spinner slip all the time on the crankshaft and I want to know if I a put some drops of the CA glue if that method will fix my problem because if I tight a little more the nut the crank will brake.
