RCU Forums - View Single Post - nikko seawolf
Old 08-21-2004 | 09:29 AM
gulfstreamI
Default RE: nikko seawolf
ORIGINAL: magnumball
do you have any pictures of the guts on the seawolf?
Photo# 1 is the front view of this sub's WTC. I used a "C" size battery to give other here an idea on how large this sub's interior is.
Photo#2 is another view of the sub's WTC. Note: the sub's serial number is found at the lower-front part of the WTC. In the back is the opening for the sub's magnetic clutch drive system for diving.
Photo#3 When you aquire a vintage submarine it is a good idea to look over the sub's entire WTC/hull for cracks before you take them out for dives. I spotted this crack on the top of the WTC near the magnet assited on-off switch. This crack can be repaired using CA glue.
Photo #4 Check this area for micro cracks. I found one in my other Nikko submarine. Check the antenna rubber plug for cracks.
ID:	166100   Click image for larger version
ID:	166101   Click image for larger version
ID:	166102   Click image for larger version
