please close thread
I would not worry about the 90 size engine it will work fine. You will not get the horse power out of either of those motors because you will not turn them that high. Can you get enough Clarence to run a 14" prop? If I could I would run a APC 14x3 or 14x5. It would give you the thrust you need with out to much speed.
