RCU Forums - View Single Post - frusturating engine problem
Old 08-22-2004 | 08:38 AM
rclement's Avatar
rclement
Default RE: frusturating engine problem
Hey RCforlife. One easy thing to check is to take out the airscrew and clean it off and blow out the fitting that it screws into. I had a problem a while back that sounds like the same you're having. I checked the clunk, checked the motor for leaks, and checked the fuel lines for holes and none of those fixed it untill I took out the airscrew and cleaned it off.
