RCU Forums - View Single Post - Homelite 33cc conversion
Old 08-22-2004 | 09:00 PM
thecutterman
Default RE: Homelite 33cc conversion
Hi, The good news is that they are the needle adjustment screws, the bad news is that you have to work to get at them. After spending quite a bit of time on the phone with a great guy at the Walbro distributor in Ohio, I found out that this is a new design mandated by environmental concerns. The guy I spoke with also found out that there is an adjustment tool, however it will not be available for anywhere from two weeks to two months. I then took my dremel with a cutoff wheel and cut back the casting around the needle screws and then cut slots in the top of the screws. It works just fine and I don't have to worry about any special tool, any slot head screwdriver will do. I hope this helps anyone else that runs into this problem
