RCU Forums - View Single Post - Low Wing or High Wing for Second Plane
Old 08-23-2004 | 06:38 AM
Fastsky's Avatar
Fastsky
Default RE: Low Wing or High Wing for Second Plane
What other flyers aren't mentioning is that low wings low wings generally are easier to handle in the wind and usually are capable of more speed and the 4* is no exception. The 4* will also have a wider speed range. Once you get used to a tail dragger you won't want to go back. No more nose gear to get bent out of shape and need adjusting. Just be sure to make very small stick movements until you get used to the plane. The turning response will be almost instantaneous compared to your trainer and could get you in trouble if you panic. If you can get a flight or two on the buddy box then you should be ok. You want also want to look at the Super Sporster. It comes in 2 sizes and has a wide speed range. Avery nice plane! Fast!
[8D]
