RCU Forums - View Single Post - Adding Oil To Your Gas???????
Old 08-23-2004 | 01:55 PM
Jim Thomerson
Default RE: Adding Oil To Your Gas???????
If you add castor oil to get up to about 25% oil you can get a modest smoke trail. You will not loose power if you set your needle a little richer to get the same proportions of methanol/oxygen as you had before. Castor goes through the engine without being burned so it will leave a fair smoke trail and oil up your airplane on the outside as well. For a real smoke trail follow the advice of those who know.
Jim
