RCU Forums - View Single Post - Servos (yet again)
Old 08-24-2004 | 05:08 PM
PaulSwany's Avatar
PaulSwany
My Feedback: (45)
Default RE: Servos (yet again)
Wow... those 5925's are way overkill.. but if you have 'em.. you can use 'em.. There is a little bit of a weight penalty... I'd go standards if I had a choice to save the weight.
You can use 4-40 pushrods or do the solder thing.. That's what I did. 1/16" music wire with a threaded coupler soldered on both ends. Again.. It comes down to weight.
The APC prop are pretty durable.. The problem with the MA props is that you loose a lot of effeciancy..... but they are more durable.. Try one out and see if it has enough pull.
