RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 08-25-2004 | 10:07 AM
  #1125
fiveoboy01's Avatar
fiveoboy01
Default RE: U-Can-Do 3d 46?
Lifting the airplane by the spinner is not the correct way to check lateral balance, as the crankshaft centerline isn't in line with the fuselage.
You need to find a spot on top of the fuse that is dead center, and lift there.
Another way to check right/left thrust is to pull into a hover and see how much rudder input you're having to give. Mine always went left(I was constantly having to input moderate right rudder to keep it pointed up), so I added right thrust to the engine till it didn't want to go the same way every time.
