RCU Forums - View Single Post - Walbro Carb MYSTERY
Old 08-25-2004 | 12:48 PM
Flypaper 2
Default RE: Walbro Carb MYSTERY
If everything is set up right including the lever arm according to specs., which should be set level with the inner carb body, and the gaskets, diaphrams in the proper order, The only thing left to leak is the rubber tipped needle valve connected to the lever arm. They do wear out too. Also make sure there is nothing on the needle seat.
