RCU Forums - View Single Post - How much weight is too much?
Old 08-25-2004 | 12:49 PM
Crashem
Default RE: How much weight is too much?
How would I add the weight to elevator? Thanks for
You don't add weight to the elevator he said under the elevator.
You can buy stick on weight just add it to the bottom of the fuse under the elevator as far back as possible. The reason for this is that it will require less weight to balance. BTW that also why someone reccomended moving the engine back towards the fire wall
