RCU Forums - View Single Post - How much weight is too much?
Old 08-25-2004 | 02:34 PM
Montague
Default RE: How much weight is too much?
I've been using the stick on weights (I prefer the other brands besides GP, but I suspect they are all close enough) for quickie CG adjustments, they generally stick through most things you'll do as long as the surface you are sticking it to is clean and dry.
If you want it to look nice, cut a small hole in the bottom of the fuse covering way back, and epoxy the weight inside where it can't be seen.
