RE: How to use polyerethane ( gorilla) glue
I would wet both surfaces then just inject the glue or just push it in with a popsicle stick. Then just wipe off the excess as it foams out. Alchohol and a paper towel works good. You really can't screw this up with this glue. By wet I mean just a cue tip with water on it. If you don't do that it would probably be fine also. Are you in a humid area?
