RE: PC-9 Seaggul elevator hole missing, please help
Hi Pascal
Re your Seagull PC-9 missing elevator rod exit cutout.
The instruction manual depicting dual elevator threaded rods, horns and clevis' setup is wrong.
The Seagull PC-9 now only comes supplied with a single 2mm threaded rod for the elevator. This exits on the same side as the rudder rod. ie: under the RHS horizontal stabiliser.
If you look again, you will find a slit for the elevator rod already pre-cut beneath the covering. It is identical in length and depth and located precisely 28mm centre to centre above the slit for your rudder.
Where in Switzerland do you fly?
