RE: GWS formosa
okay I have another question. As i will be using a typhoon outrunner 15 motor on the formosa, i have managed to get a Ply GWS Stick mount so I can attach the motor with hopefully no problems. I have a Kontronic Swing speed controller which I shall be using. as for the battery.
I have a CP1300 mAh 10 cell pack. Will this be too much for it as in weight or what ? I dont want to go to Li-Po's or lithiums on this model as I have the speed controller and its only for Nicad or NiMH and I would like to use this in the model otherwise I consider it a waste of money.
What batteries are you guys using that are NOT Lithium or lipo and also what size prop will go best.
Once again Many thanks for all your input.
Keith (UK)
