Thanks guys!
Fastlash, the little thing is covered in clear and white monokote. Fuse is built square with extensive tri-stocking. I then sanded the entire fuse to a round cross section.
My unlimited plane is essentially a long wing version of this plane with a slightly longer nose to better balance the plane and provide more room for the fuel tank. The little canopy is actually functional. It houses/streamlines the aileron servo which is sunk inverted through the wing. I have not yet decided whether or not to use a Vtail on the Unlimited.
