ok, i hit the setup button for 2 seconds, held it neutral, hit fullthrottle, full reverse, neutral, then hit setup again, its still doing the same thing...also, ive noticed the motor is not making a wizzing noise when you try to put it in forward, which it seems to overcome if you give it more throttle (the car doesnt move forward with just a slight touch anymore) also it does move backwards, very very slowly, and the wizzing noize is still prevelant...what the heck is going on?
