RE: Engine Vibration
Thanks, I patiently balanced the prop with a TF magnetic balancer both laterally and longitudinally. It is balanced so it can be positioned at any point without movement, took about an hour. It is a Master Airscrew 10x6 and was disgustingly out of balance right out of the box. I did not balance the spinner, however, as it runs true using a dial indicator.
