RE: Should wide,flat trailing edge be included in Chord?
BMatthews, that sounds interesting to me to glue the lower panel to the top one. Would I keep the ailerons drooping in line with the downward angle of the top panel?
Would you think this would be a better performing wing for a Trainer as opposed to the one with the top panel glued to bottom?
Also, that reflexed undercambered section causes more drag than a flat bottom right"
Matt
