RCU Forums - View Single Post - toque roll out of hover
Old 08-02-2002 | 06:21 PM
RickP's Avatar
RickP
Default toque roll out of hover
Yes,
Double what wayne said. The plane will be very stable leaning forward a bit. I just learned the hard way, but did learn to hover well in the process. Just do an elevator and feed in one click of throttle at a time (well below half) untill it stops falling. At this point you will be hovering and you can use the rudder to steer it around. I got quite good at this.
That was where the problem started. What's next? more throttle, and then it went full vertical and right into a torque roll. You'll wanna make sure you are at least two mistakes high. One's not enough, I know LOL.
Rick
