RCU Forums - View Single Post - H9 edge 540 problems?
Old 08-29-2004 | 05:47 AM
Vortec's Avatar
Vortec
Default H9 edge 540 problems?
Hi guys.
A fellow flyer has just rebuilt this plane after a mishap on its maiden.It is running a saito 180 4s and it flys realy nice,motor needs some more running in but the problem is when he does loops it tends to roll out of them when he passes the top section of the loop.It will roll out till it is flying straight and level again.
It cant be snapping surely at slow speeds? As it flys realy well at slow speeds with out a wing tip stalling at level flight.
It does drop a wing if too much elevator is used like in most of the posts on here about the 540 but this is not realy a stall but more of a roll as the end of the loop is done.
It makes this pilot not realy confident to get it down as it might roll at the wrong time again and go in..
Anyone have the same problem with the Hanger 9 edge? Not many posts on here saying this plane is very good? Plz share your thoughts,as this friend realy likes this plane.
