RCU Forums - View Single Post - FS70 Surpass 2 muffler question
Old 08-30-2004 | 11:27 AM
Bax
Default RE: FS70 Surpass 2 muffler question
Your engine's idle mixture is most likely too lean. Richen it a LOT, start at part throttle and then work on the high-speed setting. Run at full throttle, very rich, for breakin. Gradually lean the high-speed needle. Once the engine will sustain running at peak RPM, you can retard the throttle and work on the idle mixture.
