RCU Forums - View Single Post - H9 edge 540 problems?
Old 08-30-2004 | 01:25 PM
gsmarino2000
Default RE: H9 edge 540 problems?
One more thing to check is if a wing is twisted up at the tip. This creates "wash-in" which makes that wing extremely prone to tip stalling.
I had that problem with my first YAI Edge 540 wing. If you had enough elevator control to land the plane, you had enough to cause a snap - and always in the same direction. Landings were really hair-raising events. I finally tracked it down to the wing twist. The replacement wing is straight and it is a completely different plane to fly. No snapping out at all with normal deflections.
Greg
