RCU Forums - View Single Post - DF Conversion Turbine Mounting
Old 08-30-2004 | 03:21 PM
siclick33
Default DF Conversion Turbine Mounting
I have just got hold of a PJP Eurofighter. I am still at the planning stage at the moment.
It is the turbine version of the kit that was originally designed for DF power. I think the only difference is that it comes with a rather nice twin walled metal tail pipe. The inlet ducts look to be the standard DF Epoxy ducts.
I am planning on using a Wren 54 (possibly Mk3)
My questions are.
Where do I mount the turbine? How far behind the inlet duct should the engine be? Should the tailcone of the engine be inside or in front of the tailpipe?
Should I use a bypass? Will it be of benefit to do so?
Do I need to heat protect the rear of the Epoxy fuselage?
ID:	168841   Click image for larger version
