RCU Forums - View Single Post - porpoising - need help to stop it!
Old 08-30-2004 | 04:09 PM
pompebled
Default RE: porpoising - need help to stop it!
The trimtabs on the drying rack are proper ones, the fins on he Triton Cat need to come off, or the boat won't be able to make a narrow turn if your life depended on it, I know, I had them on..
For testing purposes you can tape a piece of plastic card onto the bottom of the hull, let it stick out behind the transom, a credit card cut in half if about the right size (no, not the gold one!). If the boat runs better/well, glue them on permanent, after sanding off the ink, making them white to go with the hull. A little(!) heat will bend them downward if need be.
The added drag is negigible.
Regards, Jan.
