RE: U Can Do 3D
contempo.. had you flownt he 16x4W or the 16x6 apc props? Did you notice a big difference in stability from those and the 17x4W? Like... hover trying to fall out and a lot of twisting until you put the 17x4w prop? Basically.. I think the difference is I was getting the same pull at lower rpms and had less torquing? Is that possible?
