RE: Need Advice: Prop Savers
I use prop savers on my foamy 3D's. It saves me a lot of props. I've made them myself and used the gws ones. They both work. Not sure if they would save you stripping a gear. For that you need to cut the throttle just before the prop hits the ground on touchdown.
