The elevators are independent and have separate channels on seperate servos. No slop in these linkages.
Good point though...I will check to see if the deflections are the same!
JC
ORIGINAL: joeb102072
Are they independent elevators or connected. In either case check the slop from one side to the other. Sometimes theres a lot of play still left in the oposite side of the elvator where the sevo isnt. And in an aggresive manuver one side may respond quicker or even with sligthly more control than the other because the point of contact where the horn is is so far away from the oposite side of the elevator. My brother has that issue with his Funtana. He found a fair amount of play in his elevator at full deflection oposite the control horn end. And i have independent elvators in my Giles and had an issue similar. Turns out I had to tune down one side it was throwing a bit more than the other. Just a suggestion. Good luck.
