RE: Something besides CG?
Try a few ounces of noseweight to move the CG to around the 27% point for your next flights. Just because the instructions SAY 30% it may not result in a model that's right for what you are used to. Once flying well you can do some low to high throttle or diving tests to determine if the CG and resulting elevator trim is close enough to neutral for your tastes.
