RCU Forums - View Single Post - UcanDo3D .46 3D trim question
Old 08-31-2004 | 08:27 PM
rc4me2
My Feedback: (13)
Default RE: UcanDo3D .46 3D trim question
I moved the CG back and aligned the elevators for equal deflection.
Good News: I did some successful parachutes without the wing drop/spiral. Hover was also improved. Landing was a little like dancing on a bowling ball - the nose came up at reduced throttle.
Bad News: Even with the CG way back, I still needed "up" elevator trim. I decided to investigate some more. At higher throttle she wants to go down. Back off the throttle and she goes nose high. It has to be a thrustline problem. I believe that I have downthrust in the model. I'll get out ye olde incidence meter and see what it says. Sheesh, these things are jig-built aren't they? The thrustline should be spot-on.
I'll report back.
JC
ORIGINAL: 3D-kid330
If you still have to push down, then that sounds like the CG needs to go back more. Nose heavy tends to like to snap/spiral.
