RCU Forums - View Single Post - Getting an 8103 to work with AFP?
Old 09-01-2004 | 04:11 AM
Imac Kiwi's Avatar
Imac Kiwi
Default RE: Getting an 8103 to work with AFP?
Spacey's right
I just tried my X-3810 on AFP. Select a fresh model memory, set it to acro, set modulation to PPM.
Go into your AFP controls, select new controller and name it 3810 and calibrate it. You can then set it up to use basic functions on AFP and make any changes in the AFP program or do what I do and set up flapperon,etc and use the mixing in your tx.
Hope this helps
Alan
ps 8103 is the USA designation for the same tx. 8ch-10 model memory-3 types
