RCU Forums - View Single Post - piston stopper
Thread: piston stopper
Old 07-31-2002 | 03:32 PM
gubbs3
Default piston stopper
It would be better to just use a glove to hold the prop. I wouldn't feel safe putting that much stress on the rod.
When I raced r/c cars I used to fill the cylinder will after run oil and then put the plug back in to lock the engine. The only time I did that was when the flywheel had come loose and the nut was still tight (loctite).
